My machine runs through al the cycles but will not extract on final spin. Please help!!!:eek:
does agitate ( wash clothes ) ??
I have Maytag Naptune front load washer (model MAH4000AWW) not extract water at the final spin cycle. I did check the doorlock, the wax motor, the pump and they work fine I did perform the motor control and board dianogsis. They work fine. I did replace the new machine board but it did not solve the problem. I already returned it back. I did unplug the washer for a few hours and replug it in but it still did not work. Sometime it work once and go back the same prolem. What can I do ? Please help me !!! :confused: :confused: :confused: :confused: :confused: If someone Magtag repair technician please give me the idea what parts I can replace in order to solve problem.
