AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Frigidaire Washer will not run but lights are on
My Frigidaire front load washer will not start. I ran 2 loads of laundry and started a third but it would not start. The lights are on and I waited 1/2 an hour to make sure it was not overheating. I had it on permanent press setting. I changed it to normal setting and it is now working properly. Can you help me?
If it operates normally in one cycle but not in another the likely problem is in your control board, which will have to be replaced (or you can just use the normal cycle and see if at sometime in the future it corrects itself. It has been known to happen. Usually about the time you call a repair tech out).
Good luck, let us know if things change
Washer Repair
