![UserPostedImage](http://forum.appliancepartspros.com/attachment.php?attachmentid=1092&stc=1&d=1244422676)
Ok, first -- this diagram is useless:
http://www.appliancepartspros.c...d=903047&NewWindow=1I have figured out how to replace the gasket -- I took a few pics along the way.
1) remove the front panel (there are two screws needed for this):
![UserPostedImage](http://forum.appliancepartspros.com/attachment.php?attachmentid=1087&stc=1&d=1244422676)
The front panel now slides down and off, no other srews are needed on this side.
2) remove lower dish rack (I neglected this step, I wish I had since it will give you more room to work)
3) remove one of two hinge screws (this seemed like a good idea to allow the door to swivel and not have to disconnect any wires)
Just the bottom screw of the two (both sides).
4) swivel the door to give you better access (or course you can skip all this nonsense if you have small/nimble hands -- I don't)
5) with the door swivled you should have easy access to push the gasket into place. I don't have a shot of the place for the gasket -- you should bee able to see the slot that is open on the left and close near the end on the right -- this matches the notch in the gasket) -- here is the correct gasket orientation:
(Sorry for the low res / I was taking these with my blackberry as I decided to document this in case it worked) The notch is on the bottom left in this picture -- if you slide the gasket in just behind the inside of the door (the white plastic) in this orientation (there is a tiny slot just on the other side of this inside door piece) you should be all set. For mine the ends stuck out a bit, but they don't seem to have affected the seal.
6) if the gasket is in place you should be able to see it when you close the door (to align the bottom hinge screws):
The gasket is highlighted in red (love photoshop) -- without this gasket water just sprays out of this hole, hits the inside of the door cover and pools on your floor - joy!
7) put the lower hinge screws in, put the front panel on (two screws) and have a really good night out with the fellas (and tell em how you saved $100 bucks on the service call).
Mine's holding up well (dry) but I will keep an eye on it (seems like a poor design and the gasket can fall out (as my original one did -- sadly it fell into the heating element and melted requiring me to buy one on this site for $11.
BTW -- Here is the old and new gaskets (old on top, new below):
The old one had a side flange -- we'll see if that is going to be critical over the next few washes (since the new one is missing that detail). Since the new one is a bit longer I doubt it'll be a problem.
kartman attached the following image(s):
