laudusk
#1 Posted : Sunday, May 31, 2009 10:37:09 AM(UTC)
laudusk
Suddenly, the inner burner of the triple burner on the R.F. stopped working. The outer two rings continue to function.
When I turn the knob to counter clockwise to turn on only the inner burner, the burner-on light goes on, but there is no heat and the heat-on light does not go on. When I turn the knob clockwise, the inner burner does not go on, but the middle and or middle and outer burner rings do work.
Any suggestions on how I can fix this?
#2 Posted : Sunday, May 31, 2009 1:07:55 PM(UTC)
Model Search
Could be that section of the lelement is burned out. You will have to check it with a meter.
Here is a service manual and a tech sheet that should help.
http://www.servicematters.com/m...ibrary/docs/16023416.pdf
http://www.servicematters.com/m...ibrary/docs/16027361.pdf
laudusk
#3 Posted : Saturday, June 6, 2009 7:16:39 AM(UTC)
laudusk
Thank you denman.
I took the top off and tested the triple element. Got readings for the outer (~10 ohms less than spec - 72 instead of 82) and middle element (52 instead of 57), but the inner element returned 0 ohms. It seems then the inner element is defective.
With this information and looking at the parts list, it seems I will need to replace the entire triple element (and not just the inner element of the assembly). Am I correct?
Thank you for the advice and the documents - they have been most help and I am very appreciative.
Dan O.
#4 Posted : Saturday, June 6, 2009 10:26:01 AM(UTC)
Dan O.
It seems I will need to replace the entire triple element (and not just the inner element of the assembly).
Yes. The triple element is a single part. If any of it has failed, the whole thing must be replaced.
LINK > Maytag MER6875B Triple Element (no picture)
JFYI
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
