usha shah
#1 Posted : Friday, June 5, 2009 4:07:29 PM(UTC)
usha shah
Side by Side refrigerator. Water leaks from the freezer side onto the floor. Do not know what is wrong.
woodchuckie
#2 Posted : Friday, June 5, 2009 4:20:55 PM(UTC)
woodchuckie
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer
Refrigerator Leaks at bottom of freezer (Refrigerator & Freezer Repair)
by rbennett 6/5/2009 10:12:26 AM(UTC)
