tom johnson
#1 Posted : Thursday, June 4, 2009 7:55:04 AM(UTC)
tom johnson
My microwave turntable stopped turning. If I take out the tray and racks it turns. I've tried WD-40 but no improvement. Can it be fixed? Thank You.
#2 Posted : Thursday, June 4, 2009 12:29:30 PM(UTC)
Most likely the problem is a bad coupler. The model number you posted does not come up.
tom johnson
#3 Posted : Thursday, June 4, 2009 12:47:00 PM(UTC)
tom johnson
Thank you for the prompt reply. I looked at the label again. It's a Sharp model number R-9H84B made in 1994, FCC ID APYDMR0088. That's all there is for information. Is 1994 too far back to get a part number?
#4 Posted : Thursday, June 4, 2009 1:15:54 PM(UTC)
The model number does not come up because Sharp does not publish any technical information on line, but I was able to find the after market part which is exact replacement for this part.
UserPostedImage
- The part number for the coupler is AP4349795
tom johnson
#5 Posted : Friday, June 5, 2009 3:59:59 AM(UTC)
tom johnson
Thanks Again. Can the coupler be removed without taking the microwave apart? If not, is it simply a matter of removing the bottom sheet metal, unscrewing the turntable motor, replacing the coupler and re-installing the motor?
tom johnson
#6 Posted : Thursday, June 11, 2009 6:23:44 AM(UTC)
tom johnson
Gene,
I took out the coupler and it was broken. I ordered the part number you sent. When I took out the part, the broken piece disappeared. Is this a potential problem? Also, the motor works and I'd like to lubricate it. Does it come apart or is a spray lubricant enough? Thanks.
#7 Posted : Friday, June 19, 2009 11:38:12 PM(UTC)
Sorry for the delay. The motor is not serviceable and do not worry about this broken piece.
Guest (4)
Microwave turntable runs when door opened (Microwave Repair)
by archiek 1/26/2015 10:12:16 AM(UTC)
Magic Chef Microwave Turntable Stopped (Microwave Repair)
by footloose1ab 11/14/2013 12:11:25 PM(UTC)
microwave turntable stops turning (Microwave Repair)
by blnp64 1/25/2013 9:55:38 AM(UTC)
Microwave turntable repair question (Microwave Repair)
by Ummagumma 3/29/2012 8:02:04 AM(UTC)
Microwave Turntable Motor Question (Microwave Repair)
by tomjonesrocks 3/2/2012 9:06:11 AM(UTC)
Microwave turntable not turning (Microwave Repair)
by richard Keller 4/26/2011 8:32:50 AM(UTC)
by raggediean 1/8/2011 1:56:57 PM(UTC)
Microwave turntable, interior light,fan and hood lights not getting power. (Microwave Repair)
by patriotins 7/29/2010 7:57:02 AM(UTC)
Microwave turntable won't turn (Microwave Repair)
by TheronSapp 6/4/2010 4:18:57 PM(UTC)
ge microwave turntable turns constantly (Microwave Repair)
by mikerozell 5/4/2010 6:58:39 AM(UTC)
Maytag microwave turntable, fan, light don't work (Microwave Repair)
by vzsxsy 4/30/2010 5:42:31 AM(UTC)
Panasonic microwave turntable turns when door opened (Microwave Repair)
by nightdog 2/6/2010 6:27:40 AM(UTC)
Sharp microwave turntable won't turn (Microwave Repair)
by retirednhapy 9/22/2009 7:57:47 AM(UTC)
Frigidaire Microwave turntable won't turn (Microwave Repair)
by djo 9/12/2009 6:02:05 PM(UTC)
Microwave turntable will not turn (Microwave Repair)
by janetlmo 6/16/2009 10:07:08 AM(UTC)
