My dishwasher will not drain - I have checked the lines and no blocks or pinches - I have check the power running to the pump and it is active- I have also removed the pump and nothing blonking it - I can hear it cut on but will not suck water through - I would like to know if there is a way to check if the pump is working - before i purchase the new pump - I belive this to be the issue but - this is my first time lookin internaly at a dishwasher please inform me of a way to check the pump before i purchase another one. thanks so much for the help
THIS FORUM IS DEAD!!!!!!! |
How do I check the check valve and were is this located?
Thanks for your reply as well
Item 58 in Motor and Pump section |
