hecdav1
#1 Posted : Tuesday, June 2, 2009 1:06:47 PM(UTC)
hecdav1
Can Not Raise Temp Above 350deg May Lower It But Can't Increase Above 350 Deg What Is The Problem? Need Some Help Does It Have Lock Temp Funcion Or Lcd Controller Bad??? Help Please
Oven Works Turns On Only No Higher Then 350deg
Dan O.
#2 Posted : Tuesday, June 2, 2009 6:51:20 PM(UTC)
Dan O.
Quote:
can't increase above 350 deg. what is the problem?
I can't think of anything that could cause that besides a problem in the control itself.
LINK > Maytag MGR4452BDW Electronic Control
Quote:
does it have lock temp funcion
Any lock-out feature would usually totally prevent the temperature from being set, not just above some mid-range temperature.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
