Joeknight
#1 Posted : Thursday, December 20, 2007 10:28:09 AM(UTC)
Joeknight
What would the OHM be on a working lower oven broiler element?
kawfeeman
#2 Posted : Friday, December 21, 2007 6:25:39 AM(UTC)
kawfeeman
just a few ohms of resistance usually ... more importantly, check each terminal to the exterior of the element to make sure the core does not have any continuity to exterior .. as long as you have some continuity between terminals is usually fine...
Lower oven heating element does not heat up (Oven Repair (including Ranges and Cooktops))
by msterren 4/16/2016 8:45:48 AM(UTC)
lower oven heating element does not get hot (Oven Repair (including Ranges and Cooktops))
by rbotthof 11/19/2009 7:46:01 PM(UTC)
