i have had this dishwasher in storage for 12 months. i have just plumbed it in and its not working. i put it on a rinse cycle and i can hear the motor wurin (well making a sound) then it stops after about 10 seconds. i cant hear any water going into the machine. its as though its asking for water but not getting any. what could the problem be?
Sorry cannot find any info on this unit ADP prefix comes up as air conditioners. Is it a US Model?
Check that the water valve is getting voltage when it should. Loosen the fitting from the plumbing to the water valve till it starts to drip, to make sure you are getting water to the valve. If it is getting voltage and water, remove and check the valve, the filter screen on the inlet side of the valve could be plugged. Could be you knocked some crud loose when doing the plumbing. If it is plugged clean it, do not remove it as it is there to keep crud out of the valve which could hold the valve open and cause a flood. Also I would run some water into a pail/pan just to be sure all the crud is cleared from the lines.
If it is clean then your water inlet valve needs replacing. |
THIS FORUM IS DEAD!!!!!!! |
