kschrei
#1 Posted : Thursday, May 28, 2009 4:39:22 AM(UTC)
kschrei
The renter I have reports that the Error Code F3 is the prevalent one of several different ones they see. The listing of error codes I found says to measure the resitence on the oven sensor. My problem is I don't know where to locate the oven sensor and how do I gain access to it. I have to believe it's an easy part to replace if I knew where it was.
I have tried to locate that part number on GE site, I don't find that, but I do find others that are close to that. Are the oven sensors likely to be interchangeable or do I need to figure out why the model number of the oven doesn't show up as exact.
thanks,
ken
Dan O.
#2 Posted : Sunday, May 31, 2009 5:39:47 PM(UTC)
Dan O.
You can see the oven sensor for that model and read about testing them at the following links:
LINK > GE JSP34W0W1WW Oven Sensor
LINK > How do I check an oven temperature sensor?
JFYI
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
Guest (4)
