I'm looking for a parts diagram or how to video on where to install part Guide,water MEA64230001 / AP6236935
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0  Location: TN Was thanked: 14 time(s) in 14 post(s)
BRGUST, with the lower spray arm and filters removed, there should be a small slot in the original water guide facing towards the wall of the sump under the large filter where a small flat screwdriver can fit. This will allow a tab to be disengaged so that the guide can lift up and out. The new one will press into place.
