Stubblefield
#1 Posted : Thursday, June 13, 2024 5:47:53 PM(UTC)
Stubblefield
United States
Kenmore Elite Model:#25344723100
I need to replace the condenser fan. It should bePart #240525401 Replaced by #5303918774. I have watched the video on this part number and the condenser is on the left side of the coils. I have been unable to find an accurate schematic of this model refrig. Looking thru the front bottom of the refrig it appears that the condenser is behind the coils. If this is correct, I am concerned about the difficulty replacing the condenser motor before I pull the refrig out and order the part. Do you have a video for this part number that shows replacement when the condenser is behind the coils? Or a pdf step by step replacement would be great. Thanks for the help
applianceaid1
#2 Posted : Thursday, June 13, 2024 8:25:24 PM(UTC)
applianceaid1
Canada
Was thanked: 10 time(s) in 10 post(s)
The parts breakdown that I saw showed the compressor, then the condenser fan motor and then the condenser coils.
Please keep in the mind the parts breakdown are just drawings and things may not be exact as pictured.
It has this one linked here as your correct one and the parts link has a video that may or may not help as it shows the older motor but it does appear to be in the correct spot like yours.
I hope something here helps,
jeff sr.
Appliance Repair Aid
https://www.applianceaid.com/
WilliamM/APP Team
#3 Posted : Saturday, June 15, 2024 6:51:45 AM(UTC)
WilliamM/APP Team
Groups: Moderators, APP Team, Registered
United States
Was thanked: 14 time(s) in 14 post(s)
Stubblefield, thank you for your question. The following link has a repair video available that would be very similar to how the repair would be with the model number provided. https://www.appliancepar...303918774-ap6034262.html
Guest (4)
