AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Can you adjust pressure switch.Because super is like large
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Can make adjustment?Its the GE hydrowave.
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0  Location: TN Was thanked: 14 time(s) in 14 post(s)
Unfortunately, the pressure switch WH12X10412 is not adjustable. Since the high-efficiency appliance era began, the water fill levels have not been what many are used to as washers are designed to utilize less water.
Washer Repair
