ddscz
#1 Posted : Thursday, May 28, 2009 2:30:01 PM(UTC)
ddscz
2003 Maytag model # mavt634aww leaking lubricant directly below agitator.More like a fine greasy dust.Is the transmission dying or is there a seal to fix? Thanks
sidfink43
#2 Posted : Saturday, May 30, 2009 4:07:20 PM(UTC)
sidfink43
Here's a technical bulletin on your machine about a new type of seal.
http://www.servicematters.com/m...rary/docs/TDL-0086-B.pdf
You can pull the agitator and check things out, but I think you are likely headed for a replacement washer. Nothing good can come from having grease from the drive train.
Sorry about the pessimism. Good luck.
