Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
hi, my washer is making banging noise and the inner tub has some play. looks problem may be the bearings. i've disassembled washer and removed tub and its clips but cant figure out how to separate the tub halves. It's almost like they are glued together. is there way to separate them and replace the bearings? thanks
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0  Location: TN Was thanked: 14 time(s) in 14 post(s)
Thank you for your question. Unfortunately, the bearings are not available separately from the full tub assembly WPW10409997. As this is the case, the tub is not meant to be disassembled.
