Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
These posts were helpful. When I reinspected the arm. I realized that in the back of the ice Maker where the metal rod and search, there is a plastic Actuator that works like And up-and-down door I simply pulled that lever down and reinserted the ice Maker and it worked properly.
Rank: Guest
Thank goodness for this forum. It fixed mine as well.
Rank: Guest
Cube ice button is sending crushed ice. Top ice maker.
Rank: Guest
Originally Posted by: alan279  Our side by side Frigidaire with ice/water in the door will only dispense crushed ice, not whole cubes. we have tried switching back and forth repeatedly but it remains stuck. Is there an easy fix or will this require a pro to attend and repair? I am very handy at fixing things but have little if any experience with appliances. If there are step by step instructions available I would appreciate any help available. Everything else still works beautifully. Thanks
