Joined: 4/16/2024(UTC) Posts: 0  Location: North carolina
This is driving me nuts!
I've replaced the evaporator temp sensor, and then the evaporator fan, as the unit wasn't cooling.
Now it's cooling just fine with 0 in the freezer side, and 38 in the refrigerator side, BUT:
Both the compressor fan and the evaporator fan almost always continue to start and stop nearly all the time, so I know something is eventually going to quit entirely, and it's loud enough that I can hear it at night when the house is quiet.
What could be going on? Should it be cycling like that?
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0  Location: TN Was thanked: 14 time(s) in 14 post(s)
KKellyNC, thank you for your question. The fans should not be cycling on and off continuously and this would be a failure within the main control if the compressor does not cycle like this. Unfortunately, the main control W10219463 has been discontinued by the manufacturer and is no longer available.
