Hello, I have an LG model number Lrsc26923tt side by side refridgerator and am having Ice maker issues. The water is dripping/overflowing after it dumps the ice and refills. IT is making ice clumps in the bin and icycles in the freezer. I had a tech look at it when it was new and said the water tube was too long and he trimmed it, seems maybe it is too short as the water is dripping behind the ice tray.. Is there an adjustment I can make? If so I did not see any screws to adjust etc? Can I buy just the tube? thanks in advance!
On most refrigerators, the fill tube is inserted in a soft plastic fitting in the back wall of the freezer. Usually, you can pull on the fill tube sufficiently to get it to reach the ice maker.
Originally Posted by: djl7780  Hello, I have an LG model number Lrsc26923tt side by side refridgerator and am having Ice maker issues. The water is dripping/overflowing after it dumps the ice and refills. IT is making ice clumps in the bin and icycles in the freezer. I had a tech look at it when it was new and said the water tube was too long and he trimmed it, seems maybe it is too short as the water is dripping behind the ice tray.. Is there an adjustment I can make? If so I did not see any screws to adjust etc? Can I buy just the tube? thanks in advance! I was having the same problem. Then my ice tray cracked so I had to buy a new one. This seems to have been a common problem with these ice trays. The new on came in and it has an extra lip so the water does not spill over. Now I can't fiqure out how to install it. Looks easy but I'm afraid to attempt. Don't want to break anything else. The new tray cost $3.70 easy solution to an annoying problem if I could only get the new one installed.
What is the part number for the ice tray? I'm having the same problem.
