Guest
#1 Posted : Wednesday, May 1, 2024 5:58:30 AM(UTC)
Guest
Rank: Guest
Groups:
United States
The timer does not advance in the Timed Dry and Air Timed Dry. The dryer runs when the Start/Stop Switch is depressed but it will not stop unless the door is opened. The timer has been replaced with the problem continuing. I cannot find a wiring diagram for this model.
The old timer was opened and there does not appear to be any issue with it with the cams rotating and clean contacts.
WilliamM/APP Team
#2 Posted : Wednesday, May 1, 2024 10:43:31 AM(UTC)
WilliamM/APP Team
Groups: Moderators, APP Team, Registered
United States
Was thanked: 14 time(s) in 14 post(s)
Does the dryer timer advance in an automatic/regular cycle?
senojev1
#3 Posted : Wednesday, May 1, 2024 11:46:23 AM(UTC)
senojev1
No
WilliamM/APP Team
#4 Posted : Wednesday, May 1, 2024 1:14:44 PM(UTC)
WilliamM/APP Team
United States
Based on the information provided, there is a break in one of the wires that supply the timer motor with voltage and/or neutral. There is a black wire spliced into the light blue wire going from the timer to the start switch that would need to be tested for continuity, as well as the white/black wire at terminal T of the timer that would be tested for continuity to the white/blue wire. If one of the wires does not have continuity, that wire has a break and the harness W11197393 would need to be replaced.
