stevekauss
#1 Posted : Tuesday, April 30, 2024 11:43:18 AM(UTC)
stevekauss
United States
A question about Bosch NGM5024UC/03 cooktop.
When I turn one knob on, igniters for all burners start sparking. They stop after the gas lights up.
Is this normal or should only one igniter spark at a time?
If this is not normal, what could be causing this?
WilliamM/APP Team
#2 Posted : Tuesday, April 30, 2024 11:46:25 AM(UTC)
WilliamM/APP Team
Groups: Moderators, APP Team, Registered
United States
Was thanked: 14 time(s) in 14 post(s)
Stevekauss, this is normal behavior in this case. When a burner is turned on, it sends 120VAC to the spark module (all switches will send voltage to the same spot) and the spark module will send voltage to all of the electrodes until it "senses" that a flame has ignited.
stevekauss
#3 Posted : Wednesday, May 1, 2024 5:22:45 AM(UTC)
stevekauss
United States
I read that this "sensing" is done by thermocouple. I checked the parts diagram for this cooktop here-
https://www.bosch-home.c...Tabs=section-spareparts/
It does not show any thermocouple. Is it using another technology?
WilliamM/APP Team
#4 Posted : Wednesday, May 1, 2024 5:37:01 AM(UTC)
WilliamM/APP Team
United States
The spark module has a grounding wire that is used to help "sense" current. When the spark module sends voltage out, the electrodes will send the voltage through the grounded burner head. When a flame ignites, the resistance of the burner head changes, allowing the small amount of leftover voltage to pass through and be sensed by the spark module through its ground wire.
thanks 1 user thanked WilliamM/APP Team for this useful post.
stevekauss on 5/1/2024(UTC)
