My Frigidaire 4.1 cu. Ft. High efficiency max Fill to load washer keeps giving me error code E5, then repeats the rinse cycle, multiple times. I adjust the drum when I get the error code, then it will start the rinse cycle over ever time. What's going on? Thank you
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0 Location: TN Was thanked: 11 time(s) in 11 post(s)
Cali.poppy, if the model number of your appliance could be provided, it will allow the most accurate information to be presented.
