cprodave
#1 Posted : Saturday, April 27, 2024 6:55:56 PM(UTC)
cprodave
United States
Measuring about 1008 Ohms (1.008 K Ohms) on suspected bad part. What should value be on a good part?
WilliamM/APP Team
#2 Posted : Tuesday, April 30, 2024 5:42:49 AM(UTC)
WilliamM/APP Team
Groups: Moderators, APP Team, Registered
United States
Was thanked: 14 time(s) in 14 post(s)
Cprodave, the most accurate test would be testing it for incoming voltage when a cycle is started. If proper voltage is present and the water supply is on with no kinked hoses, the valve would be the cause of failure.
