I bought the three way valve and replaced it and it still doesnt work so?? I did see how to put it into test mode on youtube so I've can do that. Thanks
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
You may want to try and switch hoses (cold supply to hot and vice versa)to see if that will make it work.
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0  Location: TN Was thanked: 14 time(s) in 14 post(s)
Cgrigson1, when the appliance is started, does one of the valve solenoids receive 120VAC?
