Joined: 4/11/2024(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: GA
GE 18 year old double convection oven. Top convection fan beginning to make bearing noise. In good shape otherwise. Model: JK955W0F5WW Serial: DL603496Q Best I can tell (even though the online model numbers listed do not have a '0' or 'O' in the model number like mine) Convection fan motor GE WB26T10033 I called the GE parts number and they confirmed that PN and that "This model is no longer being manufactured". Lady said she looked locally and online and out of stock everywhere (local and online). Ebay has used ones only. I found here a similar looking motor, 1 digit different (wb26t10034). And other places have others with slight difference in PN. https://www.appliancepartspros.com/ge-motor-psc-conv-wb26t10034-ap3860578.htmlAnybody know if the wb26t10034 or another similar PN would work (I can change the connector, if needed)? Edited by user Thursday, April 11, 2024 11:21:43 AM(UTC)
| Reason: corrections
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: TN Was thanked: 12 time(s) in 12 post(s)
Unfortunately, the manufacturer does not show a compatible replacement for the discontinued motor. As this is the case, it could not be guaranteed that an alternative part will mount or operate properly.
