Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
My evaporator coils have started to freeze up over the last few months. After the third time of me melting the ice, I replaced the heater & bracket assembly and the defrost thermostat. It SEEMED like everything was good for the last month, but it froze up again.
What should I do next? What could be causing this issue?
Groups: Moderators, APP Team, Registered Joined: 2/26/2024(UTC) Posts: 0  Location: Cleveland Tn
Guest,
If the heater and thermostat have been replaced then the defrost control would be the problem. We would need a model number to see if there is a timer or a board that would be needed.
