bronn033
#1 Posted : Saturday, March 30, 2024 12:57:30 PM(UTC)
bronn033
United States
Hello, I just recently replaced the rear bearing on my aeq6000es2 Frigidaire dryer. It was making a different sound now, so I took it apart again and changed out all of the felt seals, rear pulley and the plastic glides. Nearly all of the grease from the rear ball socket leaked out. I used all that came from the kit. What can I use to lube this? High temp grease?
Guest
#2 Posted : Sunday, March 31, 2024 3:42:31 AM(UTC)
Guest
Rank: Guest
United States
Best lube to use is a high temperature wheel bearing grease but not too much.
WilliamM/APP Team
#3 Posted : Friday, April 5, 2024 6:18:22 AM(UTC)
WilliamM/APP Team
Groups: Moderators, APP Team, Registered
United States
Was thanked: 14 time(s) in 14 post(s)
The hi-temp lubricant used in the rear bearing kit is part number 5303307893.
