blackwell316
#1 Posted : Thursday, April 4, 2024 5:05:48 PM(UTC)
blackwell316
United States
hello, I have a Maytag commercial dryer model # medp765fw0 it stopped heating. so I replaced the heating element and thermal fuse and all thermostates. also, the heat select. everything is showing continuity.
I have also checked the motor switches and the timer. all showing good. is there anything else it could be? I have installed the wires back according to the photo I took. if you have a photo of the wires for this, it will also help. I am at my wit's end.
my sil has a Kenmore dryer and I noticed it's the same setup but the wiring is totally different.
Guest
#2 Posted : Friday, April 5, 2024 1:00:08 AM(UTC)
Guest
Rank: Guest
Groups:
United States
Although you have probably already checked it but are you sure you have 220 volts coming in to the dryer from the wall outlet and not just 110 volts across one leg and not the other ? Was the heating element shorted or open when you removed it ? Any wire connections to the various t-stats or the thermal fuse broken but just hanging on ? Hope these suggestions help you ?
WilliamM/APP Team
#3 Posted : Friday, April 5, 2024 6:37:38 AM(UTC)
WilliamM/APP Team
Groups: Moderators, APP Team, Registered
United States
Was thanked: 14 time(s) in 14 post(s)
If there is 240VAC going to the dryer, there would have to be a wire failure based on what has already been checked.
