Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Kitchenaid KSSC48QMS02 Freezer temperature varying from setpoint of 3 to 20 degrees causing over heating light to come on. Refrigerator temperature is fine maintaining its temperature at 37 degrees. I have cleaned the coils. Any ideas???
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: TN Was thanked: 14 time(s) in 14 post(s)
The condenser coils may need to be checked to ensure they are clean, allowing the freon system to cool down properly after a defrost cycle or when cold air is called for. Also, is there a pattern to when the temperature will increase so much?
