Old pump did not do this, but new drain pump pulsates after tub is drained. Tub empties quickly as before pump replacement, however, now there is a pulsating sucking noise, on about a 1 second cycle, after tub is drained in all modes of drain operation. Almost sounds like a valve is closing and opening?
Groups ready for retrieval: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0 Location: TN Was thanked: 14 time(s) in 14 post(s)
When this noise happens, is there also a humming noise or a motor operation noise?
