Joined: 3/26/2024(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png)
Greetings. Has anyone figured out any good LED replacements for the 40-watt incandescent bulb (8206232) that lights up the stove? I'd like something brighter that uses less electricity, but I also know the socket has limitations on volts/amps.
Thanks!
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: TN Was thanked: 14 time(s) in 14 post(s)
Unfortunately, we would not be able to recommend an alternative bulb to what the manufacturer recommends. The use of an alternative bulb from what the unit is designed to use can lead to a control board failure.
