gocanada72
#1 Posted : Monday, March 18, 2024 5:53:29 AM(UTC)
gocanada72
Canada
This older machine has served me very well (knock on wood!) owned since new (25+ yrs) just started leaking out of what looks like weeping holes in the tub seal.
Removed boot seal--all looks to be in decent shape--any ideas what I should be replacing.
Pretty steady drip during use.
Any help would be appreciated!
I'm not sure how these things seal out the water--is that teflon ring (hard surface to hard surface) supposed to prevent water in tub from seeping through? Seems like a tall order for hard surface to hard surface to keep water out--can someone pls explain how this works?
gocanada72
#2 Posted : Monday, March 18, 2024 9:57:08 AM(UTC)
gocanada72
Canada
https://forum.partsdr.co...id=1443&d=1710679689
this is where it is leaking from. Seems to be coming through the small weeping holes in the seal...fairly steady drip.
anyone??
