Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I have a Frigidaire gas dryer, model # FAQG7001LW1, that is not working. As soon as I close the door the drum starts spinning even though I didn't push the start button. There are no lights on the control panel when this happens. Even if I push the start button, before or after closing the door, the drum spins but no heat.
I've seen three different possibilities from replacing sensors to replacing the control board. I don't mind replacing tue sensor but it's 10 years old now. If it's a control board them I'll just buy a new dryer.
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0  Location: TN Was thanked: 14 time(s) in 14 post(s)
As the dryer motor is operating regardless of if the interface has been activated or not, there is certainly a failure in the control 137070890NH. This could also be the cause of the dryer not heating.
