3 days ago, after a 12 hours power outage, the ice maker doesn't work anymore. I did reset the ice maker but went I bring it back up, I can only hear/see the motor trying to empty the ice tray for a second and nothing is happening. Then about 5 second after same motor behavior. NOTE: same behavior when I reset the ice maker (I did this about 5 times, twice with a 24 hours delay between, then few other times).
Any suggestion???
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0  Location: TN Was thanked: 14 time(s) in 14 post(s)
Based on the information provided, it sounds like the ice maker 243297610 motor has failed and is not completing the twist of the tray during harvest.
