adamm53
#1 Posted : Saturday, March 2, 2024 3:42:02 PM(UTC)
adamm53
Canada
Dryer Model: 110.8888291
The timer on my Kenmore 90 Series Electric Dryer is not advancing. The dryer is tumbling and heating. I am not sure which timer I need to replace the malfunctioning one.
When I type in my model number online nothing comes up.  The model number on the timer and the timer itself appears to be different from timers used on similar models.
Also, I opened it up and tested it with a multimeter. The timer motor is not working and two of the contacts inside of the timer shows signs of arching and melting.
Would you be able to suggest a compatible replacement timer?
https://drive.google.com...p32AQEti6?usp=drive_link
Guest
#2 Posted : Saturday, March 2, 2024 4:08:26 PM(UTC)
Guest
Rank: Guest
United States
There might be a timer on E bay that will fit and work on your machine. Take a look but make sure it is of the correct mounting arrangement
Guest
#3 Posted : Friday, March 15, 2024 10:45:06 AM(UTC)
Guest
Rank: Guest
United States
Did you ever find a timer of the type you need as I have a couple in my spare parts box and would be happy to send one to if knew which type. Tom H in zip code 61571
