AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Frigidaire Affinity Washing Machine - Leaking only sometimes
Joined: 2/24/2024(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: NY
Hi - I have a Frigidaire Affinity washing machine, front loading - that leaks only sometimes. It seems to drain fine, and run fines. Just sometimes, I get a puddle on my floor when using it. Any ideas?
Thanks!
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: TN Was thanked: 14 time(s) in 14 post(s)
Omf_24, if the model could be provided, this would allow the most accurate information to be presented. Generally speaking, the point of origin of a leak would need to be checked for. If the small puddle is occurring at the front, the front panel would need to be checked for any water residue streaks that may indicate the door was leaking. This is often caused by fibers on the front glass creating a breach in the door seal.
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Sorry for not responding sooner. I didn’t get an alert. The machine worked fine two days ago and leaked again today. The model number is ATF6000ES. Really appreciate any help.
Rank: Guest
Not sure how to post a picture. Today it leaked again. I could clearly see where this time. It’s at the bottom of the door. I see soap suds. Any idea how to fix it? Thanks!!!!
Washer Repair
