Rube
#1 Posted : Tuesday, February 27, 2024 7:56:33 PM(UTC)
Rube
United States
My freezer is way too cold, refrigerator is freezing food and temp readings on front panel are not accurate.
Freezer Fridge
Set temp. 0 37
Display read. 21 37
Actual temp. -15 46
The temps vary quite a bit throughout the day. Currently the refrigerator side is close to normal but foods will sometimes freeze. I can see ice build up inside the hole behind the ice maker where the wires come through. I’ve cleaned the vents and coils on the back of the fridge and already replaced the defrost sensor and the front panel. The panel was only replaced because several of the lcd segments were failing on the old panel. Temperatures displayed on the new panel are consistent with what the old panel had been showing. I have a replacement temp sensor for the freezer but haven’t been able to determine its location.
I’m hoping someone here can help me narrow down what parts I should try replacing next and also I need to know where I can find the tech sheet for this model. Whatever would tell me what all of the diagnostic codes mean when in service mode on the front panel and chart that tells me what the ohm readings should be for the sensors at specific temperatures.
Andy
WilliamM/APP Team
#2 Posted : Wednesday, February 28, 2024 11:13:06 AM(UTC)
WilliamM/APP Team
Groups: Moderators, APP Team, Registered
United States
Was thanked: 14 time(s) in 14 post(s)
Rube, with the power supply cord unplugged, the thermistors can be tested using the wires at connection J4-A1. The top refrigerator thermistor would be tested from the wires at pin 3 to pin 9, the lower refrigerator thermistor would be from the wires at pin 4 to pin 10, and the freezer thermistor from the wires at pin 5 to pin 11. The freezer thermistor will be located in the auger motor housing while the refrigerator thermistors will be located behind rectangular plastic housings. The refrigerator thermistors should measure around 28.3K Ohms at 37 degrees. The freezer thermistor should measure 138.3K Ohms at -15 degrees. However, based on the information provided, it sounds like the main control 5304498818 is the cause of failure. https://www.appliancepar...304498818-ap5955504.html
