Joined: 2/4/2024(UTC) Posts: 0 ![Canada Canada](/Content/images/flags/CA.png)
Hi there, I have a Kitchenaid kdfe204e and it just stops mid cycle and doesn't throw any errors that I can see. It just goes to drain/cancel. It does this on all cycles and I can run a rinse cycle with no issues. I ran the diagnostics and at the end it gives me 3 short beeps and one long one then shuts off. It doesn't have a digital display so I am not too sure if there are any errors. No buttons flash or anything of the sort either. My assumption could be a bad control board or a sensor but like I said it doesn't seem to give any errors. It was doing this off and on for the last while, it seemed like of we pushed the control lock it would work sometimes but now it doesn't seem to matter. If anyone has some thoughts can you please let me know Thanks!
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: TN Was thanked: 14 time(s) in 14 post(s)
T_mich, if the clean LED did not flash at the beginning and the end of the diagnostic cycle to indicate there was a stored error code, the failure would be in the main control.
