Fieldsafo
#1 Posted : Monday, February 12, 2024 4:00:47 PM(UTC)
Fieldsafo
United States
Noticed a grinding sound the other day. Sounded like rotor was grinding on stator. Took rotor off, had black magnet shavings. I replaced the rotor and inspected the stator and did not see any cracks but there is wear on the magnets.
I also replaced the suspension. Still have a rubbing issue. There was a rust color dust underneath which I hadn’t seen before. Makes me suspect the shaft and bearings are shot. I have replacements for them, but want any other opinions before I tackle it. Keeps throwing UL uneven load code both with and without clothes.
Am i missing something obvious?
Edit: just tried running it and got an F51 error.
Edited by user Monday, February 12, 2024 4:05:38 PM(UTC)  | Reason: Not specified
