jappel
#1 Posted : Monday, January 22, 2024 7:02:46 AM(UTC)
jappel
United States
Hello,
I've got a GSD2200Z01AD Dishwasher that is leaking out of the bottom front. It's leaking just under the door, between the bottom of the door and "base" of unit. Can't figure out how to get a picture in here. I've replaced the door gasket (AP2038876) and the door gasket insert (AP3156107). I feel like I installed them correctly and there was no previous insert installed.
Dishwasher still leaks in same location and looking for some help on what to do next.
Thanks,
Jason
WilliamM/APP Team
#2 Posted : Tuesday, February 27, 2024 7:11:36 AM(UTC)
WilliamM/APP Team
Groups: Moderators, APP Team, Registered
United States
Was thanked: 14 time(s) in 14 post(s)
Jason, the water level will need to be checked to make sure the dishwasher is not overfilling. If it is not, the next step would be checking the spray arm for any cracks or clogged jets. This can cause the spray arm to not rotate properly and create waves that will leak out the front.
