Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Model is Amana BX21* or BC21* (1998) The freezer is not working properly. When the compressor starts, everything freezes fine, but it often stops working and everything starts to thaw. The fan is working, but the starter relay isn’t starting the compressor reliably since it’s an older machine I’m having trouble finding the right parts to order. The models numbers above are exactly how it’s written on the label, but are not to be found online. Any thoughts?
