Rank: Guest
Groups: Guests
Joined: 8/10/2018(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 99556 Was thanked: 4 time(s) in 4 post(s)
My washer will not drain. I did the diagnostics test and it throws the code for drainage issue. I replaced the drain pump and that was not the problem. What other issues could be causing the drain problem? I’ve flushed it quit a bit with testing the pump. Seems anything plugging has come out. Could this be my circuit board? It seems like the washer isn’t communicating to the pump to activate it.
