Hello, I just converted the stove from natural gas to Propane, Installed the replacement orifices and turned the Manifold Piece from Nat Gas to LP. the stove appears to works ok, but when I start the oven the flame is so High it comes through the bottom of the stove and Is Extremely High, and Yello Blue, Is there something I am missing? Is there an orifice for the oven as well?
Thanks in Advance.:confused:
Groups: APP Team
Hi.
There is an adjustable orifice for the oven. Remove the burner and turn the orifice CW 2 turns (approximately).
Post the results.
Simon.
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Switched to lp adjusted hood flames to high
