Rank: Guest
Groups: Guests
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Our Maytag gas dryer runs for 2 - 3 minutes and then stops. Then it won't start again for 15 - 20 minutes.
A friend's theory is that something causes it to overheat so it shuts off automatically to protect the motor. This happens even when it is empty.
Any ideas?
Rank: Guest
Groups: Guests
could be the limit switches, before replacing the parts you have to clean the vents
Rank: Guest
Groups: Guests
You might want to try running this units w/o the vent hose connected to the ducting and see what kind of reaction happens. The problem you describe is usually a vent restriction which causes the unit to shut off before it overheats.
