LG French Door model LRFC25750TT. Has stopped cooling; unplugged for 24 hours and replugged with no change. I can hear the compressor clicking, but it doesn't come on. Is there something to try before replacing the compressor?
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
try to replace the relay assembly in the compressor it is best to verify the amperes drawn by compressor. if is 15 amps or more then replace that assembly
