Joined: 10/12/2023(UTC) Posts: 0  Location: Sacramento
In a move we lost the side rack supports for the oven racks from our older 30" Viking gas stove. Model number is VGR30-4B. I called VikingParts.com and was told the part, number PB06001, is obsolete and I havent seen it on ebay. There are other rack supports from other 30" Viking stoves with different part numbers but I cant tell if they will fit. Another part number that is available is PB060030 that looks similar but I'm not sure if compatible. Anyone by chance know the answer? Thanks!
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
The on light will not go off
