My whirlpool refigerator stopped cooling completely after I turned the temperature control down a little. The fan continues to run and the compressor has a low hum to it but never seems to get going. I tested the starter relay and its working so what should I try now? Got compressor running but still not cooling. Any ideas?
Groups: APP Team
Hi.
Remove the rear cover and check how the evaporator coils are covered with frost if covered at all.
Please, post the results.
Simon.
Originally Posted by: hogo ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) My whirlpool refigerator stopped cooling completely after I turned the temperature control down a little. The fan continues to run and the compressor has a low hum to it but never seems to get going. I tested the starter relay and its working so what should I try now? Got compressor running but still not cooling. Any ideas? There's nothing on the coils and never was when it stopped cooling. The compressor stays on as does the fan. What doesn't make sense is the problem started when the fridge temperature dial was adjusted.
Originally Posted by: Simon / APP Team ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hi.
Simon. Thanks for your response, there's no ice, just a mystery. The temperature went from cold to not cooling at all when I turned the temperature dial/adjustment down a bit.
Groups: APP Team
Hi.
It is a mystery. Most likely it's a sealed system problem. Before calling the pro check if compressor gets 120v.
Thank you.
Simon.
Thank you.
Simon. If the overload relay is faulty would the compressor run but not cool?
Groups: APP Team
No.The compressor would not run with bad starting components. If it's getting less than 108v it would not work properly.
Simon.
Originally Posted by: Simon / APP Team ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) No.The compressor would not run with bad starting components. If it's getting less than 108v it would not work properly.
Simon. Thanks Simon, for your help. Howard
Groups: APP Team
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 99556 Was thanked: 4 time(s) in 4 post(s)
If there is ice above the coils, would we need to replace the coils only or what else would need to be replaced? Compressor is running, and all parts on back seem ok. It just isn’t cooling. We were told by an appliance person that everything, including compressor, would need to be replaced.
