Laura, Looks like there are a host of folks you need to contact here. I will be following this thread to see if your customers receive satisfaction.
Robert et. al, Same problem on the same model (Kenmore Elite, Stainless tub). Ran through all the same hoops with Whirlpool and Kenmore for the recall, same result. Logged the complaint with CPSC. This seems to be the best course of action. If enough people report the problem, they will issue a recall. There are already a number of incidents at SaferProducts.gov . Obviously this is a manufacturer issue where the tub leaks into the control panel and starts the electrical fire - and it is reported on numerous models from 2004 - 2006. But unless the "exact" model number is reported, there will be little recourse. The right thing to do is replace the seals and control boards on all these affected models, but whirlpool ain't going to do that w/o a class action lawsuit.
Hi all, I now have over 300 incident reports to share. A couple of new TV news reports posted to view. And a breakthru announcement coming soon... steve@kitchenaidfire.com
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
My Kenmore dishwasher caution fire !!! OMG?? Less than 7 years old
Rank: Guest
Kenmore 665.13862K602 Control board P/N 8575276 WPW10084141 Potter & brumfield relay TT7CV5D-05-01
Pin on relay. Solder joint melted that goes to heat leg. Would have caught fire. But smell allowed use time to kill the power
