Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Hi:
I have a Kenmore 110.21252112 washing machine that most of the time will not finish the complete cycle. The machine stops sometimes at the rinse process and other times stop when the LED marks the spin cycle. Sometimes it will not rinse at all and the machine do not drain the water at all and I have to remove the clothes manually and empty the water in the machine by gravity. I replace the Lid Lock Latch and the Strike but it did not work. If I reset the machine and select the Spin/Dry position, the machine will continue until the cycle is complete. Any help on this problem? Thanks.
Hi:
I checked the washing machine again and now it just wash the clothes but just stop after that. It won´t continue to the rinse cycle and beyond. I run the diagnostic test and it does not show any error code. Just the sensing led flashing. Any ideas to solve this problem?
