strick1940
#1 Posted : Friday, May 29, 2009 10:05:22 AM(UTC)
strick1940
My dryer makes a loud thumping noise when the drum turns. What is causing this noise?
#2 Posted : Friday, May 29, 2009 12:49:22 PM(UTC)
Most likely the problem is a worn out rear drum bearing. Also it can be a bad idler pulley.
Timothy S.
#3 Posted : Saturday, October 9, 2010 9:15:22 AM(UTC)
Timothy S.
How would I replace the drum bearing or possibly replace the idler pully?
